Hi guys,
Looking for some help on a crank no start problem in my jeep tj 2.5 1999.
No codes
- checked fuel pressure and check valve 45psi OK
- checked compression OK
- checked for spark OK
- checked for pulse on injectors OK
- checked for 5v reference at the sensors OK
- checked and cleaned grounds
- checked timing marks on crank and cam pully OK
- checked timing chain OK
- checked cam and crank sensor wiring for continuity to pcm plug OK
- checked pcm for power ground and 5v reference OK
(and ordered a new one from wranglerfix, same problem crank no start)
- soldered the connections of the cam and crank sensor eliminating a possible bad connector
- bench tested cam sensor (distributor pickup) with 5v supply
0.00-5.00v on signal wire
- bench tested cam sensor (distributor pickup) with distributor removed rotated shaft by hand
With 5v power supply
5.07v-0.00v on signal wire OK
- bench tested Crank sensor with 5v supply 0.00-5.07v on signal wire OK
- tested and checked distributor timing on TDC OK
- tested map sensor OK
- new properly gapped spark plugs
- new rotor
- new spark plug cables
- new distributor cap
- cleaned throttle body
Found a possible problem: when cam and crank sensor are mounted in the jeep and plugged into there connectors when backprobing the connector on the signal wire found a signal between 4.08v and 0.11v when turning the engine by hand.
For one rotation of the crank I get 10 pulses on all the injector ground wires and wet plugs.
Looks like the injectors fire as a batch and not sequential.
I didn’t find the info online but I think injector firing should be sequential.
both sensors bench test good but when mounted in the jeep there is a volt missing on the signal wire when turning the engine by hand.
Bench test and mounted to the jeep tested with same multimeter.
Both connectors have:
5.07v on the power supply for the sensors
Battery voltage on the ground with multimeter connected to the positive terminal of battery.
I am a bit lost about finding the solution and thought maybe this forum can help. Tried the search option but didn’t find my answer.
No codes
- new rotor
