What should I price a broken engine at?
LostInTheSauce
Raleigh
I swapped the 4.0 out of my 2000 Wrangler and now looking to sell it. Not sure what to price it at, just curious what some of y'all think.
It runs, but one of the cylinders was getting about 55 psi during compression test and it was getting about 13 mpg. It has 164xxx miles on it.
I've searched Marketplace and Craigslist and haven't found anything similar to base it off of.
Thanks y'all.
Edit: I should also mention it has a P0300 code, multiple cylinder misfire. And although I couldn't tell from the leakdown test, I have a feeling it has a bad piston ring(s), possibly valve seals.
Could be fixable fairly easy too. Those years had issues with the head cracking.
In my neck of the woods you may be lucky and get $100 but it will take a while to sell
can you say "stroker motor"?
mine started out as my original 240,000mi engine that had developed a noise in the bottom end...now, a 4.6L beast
https://www.cleggengine.com/jeep-4-0-stroker-kits.html
then swap the stroker in and sell the motor you're running now for a couple thousand as a running engine
Tempting. How much did that cost?
Right now it's in a friends garage, 1500 miles away, so I'm trying to get it gone for him. But he could be talked into a rebuild or stroker.
Reactions: BC Moto
back when I bought it, the stroker kit was under $1000 (follow the link, it was a stage 2 kit with a couple options added) add the gaskets and assembly lube, plus anything else you might want to replace while it's apart...like mine has a melling oil pump and timing chain, an aftermarket valve cover, and headers
