Recently picked up a 2000 TJ with the 4.0L engine and a manual transmission.
It's lifted 6" with the Skyjacker lift.
When I shift into 4hi, the engine just revs. It's as if the clutch is still engaged. Drives fine in 2wd.
I can see the linkage move from underneath and it doesn't look like it's been moved or adjusted in a long time. Aside from trying to adjust and see if I'm just not fully engaging 4hi, is there any other way to diagnose before I pull the transfer case?
Thanks for any help you can offer.
