You will need a set of HVAC gauges and hoses, and you will need the quick connects that screw onto ends of the hoses so you can connect the hoses for automotive purposes. I also recommend some teflon tape for all hose connections to ensure you have tight connections. Make sure you get gauges for the type of refrigerant that you are working with-134a for the TJs.
