What gauge/fitting set do you use for testing vaccum pressure? The ones I see are for fuel pumps and the adapters are all too large.
You will need a set of HVAC gauges and hoses, and you will need the quick connects that screw onto ends of the hoses so you can connect the hoses for automotive purposes. I also recommend some teflon tape for all hose connections to ensure you have tight connections. Make sure you get gauges for the type of refrigerant that you are working with-134a for the TJs.
No reason for Teflon tape, A/C hoses have o rings an do not seal on the threads.
My apologies for not being more clear, I'm chasing a leak on the vacuum lines that operate the interior hvac controls.
Only the defrost and floor vents work inside-im told that normally would be caused by a vacuum line leak. Figured I'd test the line in a couple of sections.
