Too keep this as simple as I can I have A/C issues.
My low and high sides are equalized before start up (70 psi @90° outside), and stay the same even with the jeep running.
The Compressor is on and the clutch appears to be engaged. Still doesn't change the pressures on either side. Changing the rpm of engine doesn't effect either side, neither does removing or adding any refrigerant.
I can disconnect the high and low pressure sensors and hear a change in the idle rpm, but still no change in pressures on the manifold gouges.
Any input would be nice cause I don't want to just load the parts cannon at this rig. As far as I know and can tell I think I might have a compressor issue.
