Gearing, tire size, and RPM
ChrisTJ98
Louisiana
I’ve read a lot of past reviews. On this forum and others. I have a 1998 TJ manual with ax-15 trans 4.0 engine currently at dry rotted 31x10.50x15 and 3.07 gears. I want to regear a dana 44 I picked up. I am debating if I will stay with 31’s or go with 32’s. This is a drive around town maybe some road trips. Very little off-road. I want to get some power back and hopefully a little better mpg as well. I would like to hear from people actually running 32’s and 4.10 or 32’s and 3.73 gears. What is your rpm in 5 th gear at say 55 mph. I currently have H&R springs and a 1” body lift. I believe 32’s will fit if I replace rims. I was thinking bfg all terrains but share your brand of tire as well.
I want to hear from people actually running these gears/tires not what you have heard.
Oh and I live in south east Louisiana it’s very flat.
Thanks
You want 4.10s with 31s/32s not 3.73s. I'm not running those gears/tires but I ran them for 10 years. I had the OE gears and tire size of 4.10s and 30.5" tires. Go to http://www.grimmjeeper.com/gears.html and plug your info in (take 1" off the tire diameter) and it will tell you what your RPM will be in any gear at any speed.
Reactions: pagrey and AndyG
Thanks I’ll give it a shot an go drive mine and see what it’s at for comparison. I wish I could remember what size came with my jeep. Seems like 28 or 29 inch tires.
measure from the ground to the center of the hub/wheel and double it. Enter that number as the tire size for accurate info from grimmjeeper
going by actual tire size from manufacture I would say Grimmjeeper is about 100-200 rpms off which isn't bad.
I’ve got the 4.0 5 speed 32 inch tires with 4.56 gears. I think it’s perfect. Manufacturers actual tire size is still not actual size when mounted on your Jeep. My BFG KM3’s probably measure just over 31 inches
Reactions: DrDmoney and L J
Just went to the garage and measured 15.5 inches from center of hub to the floor. That’s on 32/11.5/15 KM3’s with 3000 miles on them. Running stock canyons with 26 PSI. I have corrected speedometer and turn about 2900 rpm at 70 mph
Reactions: L J
I’m going by actual
Manufacture tire diameter which is a inch off. The 32 inch tire you’re running is it on a 15x8 rim? I know my rims need replacing as of years ago the tire guy couldn’t get one to balance so he used the spare tire rim. Does it really matter that much with amount of air? I run about 40 psi in my 31’s
I’m going by actual
Yes 15 by 8 stock canyons
Same here, 4.0 5 speed with 4.56 gears and 32's and think it's perfect.
Reactions: L J and GPK03X
I’m going by actual
The forum experts recommended about 28 PSI for my 32’s. I think 40 psi is a little too much for 31’s
Reactions: L J
Reactions: xXDavidCXx
Thanks can you tell me what kinda lift you have? I put H&R springs in and was amazed how much lift I got and have a 1 inch body lift on it, it sure looks like it could clear 32’s. Ran 40 psi because god it’s such a slug to drive. It needs gears bad.
I’ve got 2 inch spring lift with a 1/2 body lift. Also have 1 1/2 inch extended bump stops
