Dual Steering Stabilizer Removal
Carlosljr
St. Louis, MO
I want to replace this dual with a single. I just got a rough country one. I’m not a mechanic but I did replace my trac bar! Just wondering if I need a bracket or if anything was removed when they installed the dual stabilizer. Thank you
Without seeing the connection at the axle end, hard to say, but you should have everything to swap back. Your replacement should have either a pin already attached, or to bolt onto the drag link.
Also, take care of the rod ends on the steering... the seals are shredded...
By "steering" you mean the drag link bar? On the right side past the bolts you used to adjust the steering wheel? Or on the left side where the tie rod attaches to the drag link?
Your new steering stabilizer will bolt right into place in the same locations the old dual-stabilizer is bolted into in your photos. The piece its driver's side end connects to is the drag link, what it is currently bolted to, it's not bolted to the track bar. :)
