Body Lift Question
CMBENG1371
WV
Hi y'all, I'm new to Jeep game and just purchased my first 2004 TJ. I just realized it has a body lift and I'm unsure of the height. Do I simply measure the spacer or the space between the body and the frame? Pic below for reference.
You measure the spacer only and it would appear as though you have a 3" body lift
You can remove or cut them down to the height you want.
You'll need to replace the bolts too.
Thanks for all the replies. If I were to remove them, what would be the best route to go so the 32s will still fit? I was thinking of doing a 2 inch suspension lift with a 1BL. Or can I get a way with just the suspension lift?
Two inch spring with one inch body lift is perfect for 32’s
