New member, first post, please be gentle. While crawling around learning about my Jeep this morning I found the drivers side sway bar bolt grinding into the frame. Reading here taught me about sway bar locks but also maybe my differential was not centered. I took a look and sure enough I have more tire past the fender on the passenger side.
I have an adjustable bar that I believe has the relocated mount on the frame.
I think I just need to drop the bar, pull the Jeep over, and adjust to length.
Is that it?
Will any thing else be changed or need to change?
Thank you for any and all advice.
David
Is that it?
David
