Has anyone installed this factory switch panel from an 03 into an 02? I wonder if it would work, as I'd like to install an air gauge on the right side panel. Remove the 3 gang switch panel and ashtray and bolt this one in.
Has anyone installed this factory switch panel from an 03 into an 02? I wonder if it would work, as I'd like to install an air gauge on the right side panel. Remove the 3 gang switch panel and ashtray and bolt this one in.View attachment 26861
Ok, thanksI installed the 03 and later double din center bezel in my 99 which requires the 03 and later switch panel to be installed. It would be easier to just get an 03 center bezel then trying to modify the 02 and earlier bezels. They can be had from Daveys Jeeps for about $25.
Using the '03 - '06 bezel would require the later radio, or a different adapter for an aftermarket radio, but would also work.I installed the 03 and later double din center bezel in my 99 which requires the 03 and later switch panel to be installed. It would be easier to just get an 03 center bezel then trying to modify the 02 and earlier bezels. They can be had from Daveys Jeeps for about $25.
I have been testing this circuit with plans to make my own sPod type of box.
http://rover.ebay.com/rover/1/711-5...0001&campid=5337789113&icep_item=132120540850
