2001 frame sourcing and costs
SlamDiego
SD, CA
Think I'm finally at the point; love my Jeep, but as you can see, I think it's pretty evident the frame is done, - as a newbie here, need help on how this works and a sanity check:
1) Chrysler discontinued the 01 frames, correct? So I need to go the salvage yard/auto recycler route to replace one? Is there any centralized/efficient sourcing method to find a part like this, or is it just clicking on CL, ebay, and individual salvage sites looking for one?
2) If i do find one, am I correct in assuming that I will need to go inspect it (if local), or find a local garage to pay a few bucks to go give it a look to make sure its good enough if out of market?
3) I was told labor for a frame swap is in the low 20s in terms of labor hours - have been told to set aside $4K-5K for labor, add the cost of the frame, and buffer in another grand for the usual other parts that probably need to be replaced. So $6-7K was a ballpark from one place. Is this in the right ballpark?
4) The big question: Is it worth it? Only has 130K miles, I love driving it especially in SD, I don't know what a sale value for it would be if i did the work and sold it, a few people have said especially in this market, if you can justify the cost of repairs being < 50% of a sale price, its defensible. I really don't think this is the right time to be shopping in the new/used car market (maybe 8-12 months from now it will look a lot different), and given I love the car, I'm partial to swallowing the cost if its in that ballpark.
I'm sure I'm asking dumb questions, but looking for other opinions, sanity check, and calling me nuts for pondering not scrapping the car. Appreciate any help.
Reactions: adamdonofrio
6-7 grand would not be worth it to me. I had a major rusted frame and was up against that dame question. Since I was in no position to attempt a frame swap myself the cost just wasn't worth it. I bit the bullet and took a stab at Safety Caps. I did both middle sections and rear trail sections. I was pretty nervous but had to do something. I heard alot of why I shouldn't go that route by many who had no experience with them (kinda like the S35 vs 44 argument) I have searched and found no personal experience with the caps failing. Mine have been on for 2-3yrs without any issues.
Just wanted you know it is a viable option. Way way less expensive than laboring out a swap.
Good luck with whatever you choose.
Does not look that bad to me, maybe I am missing it. I see the one spot rusted through but I think those areas could be fixed without a frame swap, that is a big cost and effort. Good luck
I cut the bad spots out of my frame and cleaned the inside. Put some primer inside the frame rails and welded on the new sections of the frame. Took me 5 days of hard labor. Lots of cutting grinding welding and painting but it’s as solid as ever now. Even with buying a welder I had less than a grand in it. My frame was 10x worse than the pictures of yours for reference
  • Wow
Reactions: Necro
Doesn't look bad to me either. Your last picture shows the skid plate and trailer hitch. You can bolt on new replacements items for those. New style mopar skid plate amazingly is only about $120.
I think the hard part is going to be sourcing a decent new frame. I am the original owner of my 2001 and would gladly have gone a frame swap if replacements were readily availability. Ended up with safety caps and have no complaints. I only needed the middle caps and it seems just as good as new. You will have to lose those oem sidesteps but for me that was a bonus.
Reactions: 2001slvrstntj
Where did this car live before getting to Cali?
If you go the frame route here you go…
You can message this guy looks like he has a tj frame in the back of the tj tub in the picture. I know he buys tj’s and parts them out. I’ll start at $1000 and see wheee it goes. Check out this item on OfferUp. https://offerup.co/S0rP251b6rb
Since you aren’t doing the work, I can’t see the frame swap being the best idea currently, I would probably try the saf t cap route first given the condition of yours. You’ll be a lot let into it and could always do a frame swap later if needed. That will get you back to a safe, usable vehicle much cheaper.
Reactions: Vtx531
Tennessee, then NY for a few years and then SF for nine years where it was parked at 90 degrees head in on steep hills regularly - hence any “hey your frame is rusted and/or bent” feedback I kind of shrug and expect the worst given it was always foggy and parked at a 45 degree angle.
Dumb question - what are Safety Caps and where do I get them?
Admittedly embarrassed but I replaced spark plugs, coil rails and I managed to do a master/slave replacement but that’s the extent of my prowess under the hood.
I got all my stuff from eBay. Found the center sections and rear trailing arms separate but you can buy them as a single piece. I paid between $300-$400 for all the pre fabbed metal. If you only need the center skid section you can get them on eBay for a couple hundred bucks unless Biden-flation has jacked the prices up since I did mine in spring
I went down this road once. I was thinking of buying a 98 and the frame was completely toast. Local frames in my area have already been picked out so I had to look basically anywhere within a days drive....something like 750 miles. My plan was to rent a uhaul trailer and tow the new frame home. I found a good one for $1,500 and was going to make a run for it but stuff came up and I couldn't move forward with it.
But....your frame actually looks really good all things considered and I'd definitely consider that repairable. If you aren't comfortable learning how to weld if you don't know....take it to a shop that does frame repairs. They can either patch the bad sections or install the frame caps. Either way, way less that $7k.
If I were comfortable spending that type of money it would be to have a Throttle Down Kustoms frame installed.
