My 97 TJ, which has a 4.0 L 5 spd has an intermittent electrical issue. The jeep could be running perfectly fine, but then lose power and stall from not having spark, which I varified from the coil wire that goes to the cap with a grounded spark plug. I've tested the Crank and Cam sensor(after removing)by applying 5 volts and testing the output when introducing and removing a metal screwdriver, both tested good. The plugs, cap, rotor, wires and coil are all new... Any ideas or suggestions???
