Cylinder 1 Misfire
tj johnny
Los Angeles, CA
Greetings all:
I scrolled a few threads but didn't see the answer I need - which is, from wherever you are, accurately diagnose my issue :). 1998 TJ, 4.0, with an intermittent Check Engine light. Local parts store code reader says misfire, #1, with a recommended fix of replace valve springs. I suppose, but doesn't strike me as the most likely culprit. I can feel the occasional miss under load. Is this a common issue? I have to get that cleared up so I can pass a smog check in the paradise that is California.
Valve springs and a misfire don't really go together. Can you provide us with the exact code that they pulled from the reader?
Now that I can't find the paper they gave me, I believe it was P0305. I feel the occasional misfire usually going from a stop and revving through 1st gear.
I read that one but I don't have any obvious indicators of this being an issue, like constant misfire, overheating, etc. I'm really hoping it's not something as involved as this..
I would definitely start with a leak down test to rule out the cracked head. Also, pull the spark plugs and inspect that one. Post some photos so we can see what it looks like.
The first thing I would do is check the condition of the spark plugs and plug wires.
This is a 24-year-old vehicle- You would be amazed how many are still going that have never had a tuneup.
The 4.0 is one of the most indifferent engines when it comes to lack of maintenance- It will eventually do what mechanical things have to do but it will just amaze you at the abuse it will take
Yeah, I'll start there and then try a leak down. I did a complete tune up a few years ago with new from the dist. cap to the plugs after I got this thing from my sister. She was a put-gas-in-it-and-drive-on kind of owner.
Reactions: AndyG and pagrey
If the leak down is bad try the de-carbon process dumping water in the intake with the engine running, can't hurt. Plenty of threads on that process.
I may try that. What's the product you can buy to poor into the intake? Makes smoke like crazy but I've seen where people swear by it...
I think its SeaFoam but don’t hold me to it.
Reactions: tr21triton
like AndyG said check your plugs ! how many miles does it have on it ! use autolite XP-985 plugs in it !
