Greetings all:
I scrolled a few threads but didn't see the answer I need - which is, from wherever you are, accurately diagnose my issue
. 1998 TJ, 4.0, with an intermittent Check Engine light. Local parts store code reader says misfire, #1, with a recommended fix of replace valve springs. I suppose, but doesn't strike me as the most likely culprit. I can feel the occasional miss under load. Is this a common issue? I have to get that cleared up so I can pass a smog check in the paradise that is California.
