Affordable rear upper control arm options
Vader_TJ_03
Maryland
So I did an sye kit and have a new driveshaft on the way from Adam’s driveshafts. But my upper adjustable control arms are seized and if I can’t get them loose then I will need to buy new ones.
I am a college kid working with limited money right now and I know that savvy or Currie would be my best option but right now it is too expensive. So my question to you all is:
Would rubicon express or rough country arms be the better option for just my rear uppers?
I think you are going to need both upper and lower adjustables. But as for the uppers, have you tried putting a torch on them to free them up?
Personally, I’d avoid RC if possibe. Have you looked at Core4x4? Their tier 1 are cheaper but still pretty solid quality.
If I was in college, and that’s all good, but I’d pull them and go to a shop, one that’s a local, and see if they and un seize them for $20. Torch and get after it, long leverage. I’d give it a shot personally
Reactions: DougyintheBushies
I have the Core 4x4 T1 front uppers/lowers, and rear lowers (rear uppers are next). I like the Core 4x4. They aren’t cheap - BUT - they’re great quality and cheaper than Savvy/Currie. I also feel like they’re better quality than the RC. I also had a good experience with their customer service when I was looking for help….. If you’re on a budget, then you probably won’t be getting double-adjustable arms, but I would be remised if I didn’t say that double-adjustable arms would be much easier to adjust. The T1 are only adjustable on one end, so you have to completely remove one end of the arm to lengthen/shorten it. Not the end of the world, but it’s a pain nonetheless.
When I was changing mine, almost all of the bolts were seized. I ended up using a sawzall and cutting the bolts. Without looking, idk if you can get a sawzall in there to reach the uppers, but that’s what I had to do to the lowers, and the front uppers.
