Whose up for some 3 X 2 carb. fun ? First Ford Flathead , 406 FE , 289.
1965-k-code-fastback-mustang-hipo-289-tripower-rotisserie-restored-4-speed-11-1593199330.webp
You might have mentioned it elsewhere, and I just haven't read it, why did you choose that setup?
Honestly for a couple of reasons.
1) I was building a stroker engine and worried about adequate CFM to feed the 408 cid. After I'd ordered this I found a 1200 CFM throttle body that would have fit onto the Hughes AirGap intake I had.
2) Because I thought it looked KEWL as heck.
3) I'd lucked out and happen to contact the company when they had a used unit sitting there. So the normal $3500 isn't what I'd paid.
4) It hooks up to the stock PCM so it's not like most aftermarket setups like this. While it does take a little more time to tune it all the stock sensors mount onto it.
It has a progressive throttle linkage so from other owners I've talked to they say it's pretty economical for what it is.
But the ultimate reason was because I thought it was RAD as Fuck and would be unique.
Yes it is...
But really the #1 reason was that I couldn't find something with the CFM to support the stroker.
I guess I should say within a reasonable price. Most larger TBs I'd found cost what I paid for the 6pack.
What is the rated CFM and are these any harder to tune than a single TB? I know a 3x2 carb setup can be more challenging to tune than a single carb. Maybe EFI sees nothing different, just air flow at a given RPM?
Reactions: reddvltj
If I remember correctly it's 1350 CFM for the 6 pack but I'm not positive.
Ryan from FRP (Flyin Ryan Performance) says that the they more difficult to tune but it's impossible.
Reactions: reddvltj and BlueC
That's the first Tesla that I actually like. I guess ICE engine swaps will be the only saving grace for these EVs when the battery pack ultimately dies and cost 20K plus to replace. How ironic. :ROFLMAO:
I've seen that Prius at an event somewhere, but I can't remember where. Seems like it was a display and not running/driving when I saw it.
What Tesla? :sneaky:
The little Citroen is easily my favorite of the three.
T
