Where can I find a replacement dashboard cover?
Ziggy
Muscat, Oman.
I would appreciate any help in finding a replacement dashboard cover for my 2006 TJ Khaki interior, I’ve been looking for one for almost 3 months now with no luck. Any guide of where I can find would be really helpful.
What's wrong with the original?
@Ziggy please reply to him directly in this thread, don't try to send a Private Conversation message to him. You need a minimum of 25 posts here before you can open up a Private Conversation to send a message.
That is a common problem. An inexpensive option is to repair it with wire mesh, epoxy and spray paint. This will also prevent the same thing from happening in the future.
Yeah, I kept that as a last solution if there is no way to source it 😅
shipping is likely to be more than the part is worth. the above mentioned repair sounds like a cheaper fix. good luck.
Here is the one I have for sale … it’s PERFECT no broken vent mesh or mounting clips … except the previous owner must have put a phone mount and sort of left a slight pattern in the plastic :-/ …
Reactions: 707kevin
