Here is the situation, I can smell a really strong raw fuel smell emanating from the driver side rear corner.
no CEL
no visible leaks
I checked the fuel line to the rail, no leaks. Checked the rail and plugs not visible gas. No gas smell under the hood. Just very strong at the rear corner.
I left the jeep running to inspect, no visible leaks. When I stuck my head un pder the driver side rear corner the smell was so strong I thought gas would be pouring on my head. I poked around and got my hand on top of the tank a little no wetness. I poked around at the plastic below the filler neck and it seems to be pretty strong there, but no wetness.
is there a vent by the filler that can leak fuel? What would cause this? No CEL no stored codes.
thank you
no CEL
no visible leaks
thank you
