OK.. I suck. I should have been much more detailed.
First off, I already have an Auxbeam eight circuit controller for my lights, OBA etc. It works perfect. I don't need ten circuits, maybe three at most if that many, but I don't want to keep piggy backing off the cig lighter or radio. I already have something else on those. The distribution block was one I had from before I did the Auxbeam setup. I want to aux LED lighting. The distribution block will be mounted behind the glove box, high and to the right.
I have two, maybe three accessories I want at the tailgate..
- A single LED cube mounted to the over-tire cargo basket. It will be for illuminating under the rear awning for camp kitchen. It will have a quick disco so that I can unplug it when the cargo basket is removed. There will be a SPST switch mounted at the rear, probably in the plastic trim covering the rear seat belt, but certain on location. I have aux reverse lights recessed into the rear bumper so the cube will can be switched power.
- The second accessory is a 12" LED ribbon light that will be mounted under the rear Bestop Instatrunk. It will have a pin switch actuated when the tailgate is opened. Now that I think about it, that should probably be hot so the cargo area is illuminated
- Third accessory is a cig lighter outlet that will have a small power inverter plugged in. And like number two, as I think about it it could be hot since the inverter has it's own switch and fuse.
So let's revise my original question. I need two or three low draw fused circuits that are switched power.
