Question on hardtop seals
sam53
sioux falls sd
I removed my hardtop last week and when I did the foam seal stuck to the tub, of course destroying it. 1St question, do most people use a seal? 2nd question please. Does any company use a rubber seal instead of the foam junk. Thanks!
The factory gasket was 1x1/16” closed cell foam. No reason you couldn’t get that size in rubber instead.
Thanks hope some one know. May I ask, is yours glued to the top or is it loose? Thanks for your reply
Loose, but it tends to stick to the body and top after being on for a while. I waxed the tub area where it sits so it doesn't stick to the body and comes off easier.
Reactions: Rickyd
