So I'm assuming I should drain the coolant and replace all the plugs while I have the manifold off, correct? Or attempt to seal?
So far on this particular job.
Replaced the valve cover gasket, PCV valve, breather valve.
Cleaned the throttle body
Cleaned the injectors and replaced the "O" rings.
Put heat shield on the fuel rail and injectors
Cleaned and degreased a bunch of other parts...
