Is there any benefit (e.g., stopping power, or strain on steering components) to larger wheels that will result in less spinning rubber-
As mentioned before for non beadlocks method has some great choices with the nv305 that @midnightljr uses and has a big enough hub for lockout as well as 701 bead grip rims which don’t have a big enough hub but I do like the idea of a little extra something to hold the bead without beadlocks. Both will need some amount of spacer to get to the 4in of backspacing equivalent unless running lockouts.
Another option as far as beadlocks seem to go is the trail ready and race line rt232 monster bead locks (seen a lot more race lines than trail ready thus I looked into them more) that do offer a 4in back spacing wheel and a bigger hub than the methods (.82in bigger). So I think you could run 4.75in back spacing with a hub kit up front and run the 4in in the rear as an option for no spacers which I think is a cool thing. At 11 pounds heavier than method non bead locks but the whole bead lock or not discussion is another topic as most really don’t need it but they do offer benefits.
Curious to see if my thoughts with both methods and race line make sense and I’m not missing anything vital or misunderstanding it.
More space to run a big brake kit to help stopping, better tire selection at time goes on, and some slight stability stayed by @jjvw. As far as I know that’s it.
What psi do you typically go to offroad?
If only companies ie: method made wheels for us TJ guys. A nice 17x8.5 5x4.5 with a couple offset versions in the beadgrip style
Do you debead more with the 17s at 8 psi?
There are enough advantages and improvements over a 15" wheel that I don't see a reason to use a 15 anymore.
The added stability of a bigger rim comes at the expense of the rubber conforming less to the terrain. Effectively, it's like the tires aren't aired down as low.
Kinda like how a load range E tire is stiffer than a C. At the same pressure the E will be more stable but have less traction. That's what happens with a bigger rim.
Also, larger wheels are (typically) heavier than the rubber they replace, so the tire+wheel combo is heavier with bigger wheels.
Example of improper 35s -
Instead of -4 backspacing, I’m finding a lot of wheels at 4.76 or something like that. Am I right to assume that the difference makes a difference?
Is that #21 for you Boog?
At least you are finally getting the color right!
I don't buy into that. So far, I haven't seen a perceivable difference in aired down traction on my 35s between a 15 and 17 wheel.
Similar question: Does Pro Comp make decent offroad wheels?
I’ve got my eye on these “vintage” 17” rims (and no, I’m not wild about the wheels on my first Jeep now being called vintage):
https://www.4wd.com/p/pro-comp-69-series-vintage-17x9-wheel-with-5-on-4-5-bolt-pattern-polished-1069-7965/_/R-BKBQ-1069-7965
