This should be so easy. But good lord.
So has anyone done this on a 2.4 before? I went to replace spark plugs tonight due to a p0304 code that the jeep threw. On idle when I first start the jeep, it kinda sputters a bit etc. So I pulled the plugs and there's oil on the 4th plug.
It's got 190,000. and I can tell has been seeping a bit out of the valve cover, so I figured that replacing that + the O-ring gaskets should be my next course of action to make sure that plug is good to go.
I'm stuck at getting the intake manifold off. I can't get to the bolts which are on the underside of the manifold (there's one on the other side that I have to undo as well):
ALSO I broke off that lil nipple thing (PCV valve?), so I'm going to have to replace that. fml.
This is the bolt I'm trying to get to (and there's another one in the back of the VC behind the manifold that I'll have to access as well):
Anyways, any advice on how to get those bolts, or to get to that cover? special tools I should use? I feel like this is such a simple job and not one that I want to outsource, but I can't find videos of anyone doing it on the 2.4, and it's far, far easier looking on the 2.5 or 4.0 lol.
*edit, I should mention the manual shows the manifold as a 2 part thing, and it's not - it's one solid piece that won't come apart.
