Hi all,
my 2005 TJ Sport is lightly leaking oil from the valve cover left side (intake and exhaust side).
Firstly, I checked the torque of valve cover bolts, some of them, located on the leaking side, were not tight.
I don't know if the leaking was fixed (it seems to be too nice to be true and I didn't have the possibility to drive the TJ),
Probably I'm going to replace the valve cover gasket.... so that's my question:
The Mopar valve cover gasket seems to be discontinued, do you have a suggestion about a good quality substitute?
On Summit Racing I found these two:
a) https://www.summitracing.com/parts/mah-vs50266/make/jeep/model/wrangler/year/2005
b) https://www.summitracing.com/parts/fel-vs50458r/make/jeep/model/wrangler/year/2005
All suggestions will ber appreciated.
Regards
Francesco
Regards
Francesco
