just an exapmle for you.
16 busshings at $30.00 a piece equals $480.00 for all of them "Mopar price"
then you MUST press them out and back in. ROYAL pain in the a$$ unless you have a shop press.
i would go with new arms with the bushing already installed.
VERY HIGH END
metalcloak arms $1,000 no need to press the bushing saving time and headaches
https://www.metalcloak.com/Duroflex-Short-Arms-TJ-LJ-Full-Replacement-Kit-p/7154.htm
Low end. but not bottom of the barrel
Crown Automotive Control Arm Kit for 97-06 Jeep Wrangler TJ $225.00 does not have upper axle bushings. add $60.00 .... still cheaper then replacing all bushing and reusing control arms. and you dont have to worry about a press. just replace one at a time.
https://www.quadratec.com/products/56005_0110_07.htm
EDIT last minute thoughts. If you are going build it up. go with the adjustable. you can set them and if you change your setup. IE lift, SYE, need to adjust your pinion angle, you are already set up for it.
if money is a factor (it always is) go with the crown. but stay away from rough country arms. ( they are bottom of the barrel)
