I'm guessing if submersion tanks become a thing for electric car fires, then dedicated trucks with tank and lift arm like that will have to also become a responding vehicle.
Barack Obama questions why Titan submarine tragedy that killed five got MORE coverage than boat with 700 migrants sinking off the coast of Greece Video The overcrowded boat with hundreds of Pakistani, Syrian, Egyptian and Palestinian refugees went down on June 14 - two days before the $250,000-a-head OceanGate tour to the Titanic wreckage went missing. It is pictured before capsizing More |
I've got two different failure scenarios pictured in my head.
1. Hull failure - whole vessel implodes instantly like a tin can
2. viewport failure - water rushes in and fills the vessel instantaneously, hits the back wall with inertia sufficient to spike the pressure even above the surrounding ocean, hydraulically exploding the vessel from inside, a la the beer bottle trick.
Conjecture seems to be leaning to the viewport due to it now being revealed that it was only certified to 1300 meters.
The manufacturer of the Titan’s forward viewport would only certify it to a depth of 1,300 meters due to OceanGate’s experimental design. The filing states that OceanGate refused to pay for the manufacturer to build a viewport that would meet the Titan’s intended depth of 4,000 meters.
wonder how long it'll be before Hollywood makes a feature film dramatization?
I hope James Cameron makes it, but he probably won't.
From the basic understanding I have, it's rupturing battery cells that keep the fire going. I imagine spiking the pack would make that worse. Did they demo it?
How do you get the car into the tank?
When I was younger in the FD, we had portable dump tanks and tanker trucks to fill up. The pumper truck would use hard suction hoses to feed the pump from the tank
That's what happens here also , set up 1500gal. bladder and have tenders shuttle water to it. Unfortunately this is tragically slow and the fire typically has the upper hand. The bummer is this is the best case scenario for structure fires in the Rockies .
