I just don't get it. I'm pretty sure I installed everything correctly. With that said, the bracket on the transfer case doesn't seem to be pointing directly at the shift lever on the transfer case. it seems above that by an inch or two. When I shift toward low, the outer rod pulls out of the rubber grommet thing and the cable bends upward. I can't seem to get this adjusted out. Any help here would be appreciated.
