LOL you just better hope she doesn't read that or the duck will be the least of your worries ;-)
AMEN!
Took my top off!
Put on my Bikini!
Took some worn out Harbor Freight straps and secured a box in the back for tools/recovery gear/jack/mini shovel/tarp. Cut the straps down so they don't hang out the back of the jeep and flutter in the breeze.
Checked my frame and body for rust. There's some dirt accumulation in there, but no rust. Anyone have a good way to clean out these areas?
Greased zerks. I was able to get grease in 12 of the 15 Johnny Joints on my Jeep. From what I hear, that was pure luck.
JKS sway bar disconnects. Only problem is my not very mechanically inclined buddy who was helping over torqued a bolt and snapped it. Any ideas on how to get it out/what bolt I need?
They'd just take a video of you losing the trailer and post it online.I had to double check a couple times just to make sure I didn’t lose it lol hopefully someone would have honked but you never know about those Maryland drivers
Installed some heat wrap for the first time. I used 1” on the headers and 2” on the rest.
Next time, I’ll wrap the DP while it’s off the vehicle so I can do a better job. Hopefully that will be years from now.
shot the fuel rail with the temp gun after a relatively short drive from work some weeks ago- it was at 175 degrees- so i decide to do some tinkering- basically sleeve the entire fuel rail/line in the engine compartment- idea being to spray a little cooler fuel. 2 feet of heater hose and a few feet of 3/8 fuel line that i had.
