What brand oil and oil filter do you prefer?
jeepmanjerry
Clayton, CA
I Bought a 2006 TJ sport 4.0l recently. It has 96,566 miles. I had a local quality oil change outfit do the first oil change for me. This was around a month ago, tops. Now I figure I'll do some research ask some questions and try to figure out what my jeep is going to be getting from here on out. Anyone want to lend a hand and guide me through the vast amounts of data & marketing b.s.?
Sent from my SAMSUNG-SM-G870A using Tapatalk
I’ve always use 10w30 Valvoline conventional oil and Wix oil filter. I’m sure there are others just as good. I’m just not a synthetic user.
High mileage full synthetic 10w-30. Usually Pennzoil or Castrol and I check for local sales and usually get a 5 quart jug for $20-$25. Sometimes a free Purolater filter comes with but I use the OEM Mopar filter the most, have tried others, and always end up back with Mopar.
I also use STP high mileage oil treatment, ZDDP.
I grab whatever high mileage Synthetic that's on special and whatever filter is included.
It's usually either Castrol, Valvoline or Mobile1 with Fram or STP high efficiency filter.
I use to run nothing but Castrol but seem less picky these days.
Agree that pretty much any name brand will do the job. The most important part is as @ohiopatriot stated.
That said, I’m a stickler on using same same every time. My preference is Valvoline High Mileage synthetic blend 10w30 and a Wix XP filter. Every 4K miles.
Can't go wrong with any brand name oil that meets the spec and viscosity on the oil fill cap or in the manual. I have used full synthetic in everything I own for some time. Quite a few brands and viscosities. But a bit of time on the web site Bobistheoilguy.com and looking over many oil sample reports at work has convinced me that I don't really need it. Have seen several stop and go diesels go 350,000 plus on conventional 15W40 where I work and ag diesels go 20,000 plus hrs. on conventional 15W40 when I was farming as well. As mentioned above the most important thing is change it regularly. Use a good filter, Wix, Napa, Car Quest all made by Wix, all good. K&N, Delco, Donaldson are good as well. I would stay away from the orange Fram, but that is just personal preference.
B
Reactions: Phil Younger
Has any one researched for a longer than stock filter to increase the amount of filtering?
Whatever dino 10w-30 is on sale and a wix filter.
This is a common misconception. Dinosaur remains are actually quite poor at producing oil. Certainly, some eventually DID become some, but they weren't nearly numerous enough to account for the size of oilfields we find.
The great oilfields you see are typically the remains of prehistoric algae and bacteria which lived in ancient shallow seas. When they were the dominant life-form on the planet for a few billion years, quite a few of them accumulate and through natural geologic processes are eventually pressured and cooked into oil.
Not to knock you, but just to pass on a nugget of knowledge. :) (I also get to tell my Geology professors I was passing along geologic knowledge I learned from them on a vehicle forum :D)
https://www.thoughtco.com/does-oil-come-from-dinosaurs-1092003
I'll run Walmart brand oil if that's what's around. All that matters is you use the right weight, change the oil at the proper intervals, and use a good oil filter.
The oil brand (or whether or not it's synthetic) itself makes no difference at all on these engines. However, if you're the type who likes wasting money on "high performance synthetic oil", then by all means, be my guest. It's your money after all.
But I just run whatever. Usually that ends up being Valvoline or Penzoil.
