A 3/8" synthetic rope is the way to go. I replaced a couple wire ropes after they kinked with broken strands 20+ years ago, I will never go back to a wire rope. While your current wire rope is 5/16", I'd go for 3/8" with synthetic for its extra strength, synthetic is not as abrasion resistant so the extra strength provides a good safety margin. Not that in 20 years of winching have I ever needed to run the rope over something abrasive that could damage it.Well thank you very much for those recommendations, I will be sure to pick them up then and get them installed. Depending on the price I may either get the pre-filters or just buy a new filter element. I have no clue where the stock setup might be so unless I can source an entirely new unit I would imagine I’ll still be staying aftermarket. Thank you so much for the help!
The Warn has gotten me out of trouble as a youngin’ so I’m very thankful to have it. I am considering getting a synthetic rope for it instead of the braided cable. Do you have any recommendations/opinions on that?
You would be fine with a used factory air intake, they're usually on sites like eBay. My current TJ came with a cold air intake like yours and I found a used factory air intake system to replace it with.
