Any ideas why after filling my ac with freon per the specs according to this forum it doesn't come on?....No heat no ac no fan motor... fuse is good...I ran it for a few minutes after filling it and it was nice and cold
I am a little confused about your post. First you say it doesn't come on but then you said it did. You wouldn't have been able to fill it if it didn't come on.
No fan? Is the low pressure line getting cold?
Not enough information to know for sure but it sounds like you have a fan issue...maybe the fan motor crapped out?
@gatertamer with respect dude, you have a huge resource of knowledgeable people on here who are willing to help but you gotta give us something to work with! Give us some context - what model do you have, what condition is it in, what happened to lead you to filing the A/C and what are the symptoms of what went wrong. Make the effort to tell us the unvarnished story and maybe we can assist...
That explains it. Freon is the wrong refrigerant.Any ideas why after filling my ac with freon per the specs according to this forum it doesn't come on?.
Without knowing what your pressures are, it's just shooting in the dark. Suggest you pick up a gauge manifold from HF or Amazon for <$100 and start your troubleshooting there.
now there's no blower
Like R12, which is the original ozone-depleting refrigerant, R22 is marketed under the brand name Freon, and it's one of the earliest CFC alternatives. Its chemical name is chlorodifluoromethane, and while it isn't technically one of the CFCs banned by the Montreal Protocol, it belongs to a closely related class known as hydrochloroflurocarbons (HCFCs). These types of refrigerants also contain chlorine that can potentially find its way into the upper atmosphere. Effective January 1, 2020, production and import of HCFCs like R22 were phased out.
R134a belongs to another class of CFC alternatives, called hydrofluorocarbons (HFCs), that don't contain chlorine. Its chemical name is tetrafluoroethane. It isn't the only CFC alternative on the market, and it isn't the best. HFCs may not be ozone-depleting gases, but they contribute to global warming, and R134a has more global warming potential than other HFCs, such as R152a. This fact led the European Union to ban R-134a from use in new motor vehicles, effective in 2011.
The fact that the indoor fan is not working I would remove the climate control console and check the condition of the wiring and where voltage is present and not present.
From there you can determine what your next step will be.
This schematic from the FSM should assist you in troubleshooting.
appreciate it brother....the profile says what I have...it's in great condition...it was low on freon and not blowing very cold... compressor cycling too often..... everything was great while filling it worked like it always has as I said before I ran it for a few minutes after I was done cold as hell like usual...now there's no blower no heat no cold nothing what else can I tell you?....I did notice a small leak about 6 months ago.but it was winter time.
That explains it. Freon is the wrong refrigerant.![]()
I've heard that there is a push to require that CO2 be used for refrigerants in the future. I wonder if Chemours will call it Freon CO2?
