The water pump is weeping, and the mechanic that I took it to when I bought it a month ago said this. I want to do it on my own. I bought this Wrangler as a project and it needs a decent amount of work. I'm thinking of doing the water pump first because it'll help to circulate everything within the cooling system. I know the cooling fluid is old/dirty/rusty. With a bad water pump, I don't know how well it will circulate everything. I've already had the Jeep overheat once.
for the water pump to be the culprit in an overheat would require significant damage to the impeller via corrosion or cavitation. You know your Jeep though...if you're concerned that you won't be able to avoid reproducing the scenario that led to the previous overheat then it's probably best to just go ahead and drain it, swap the water pump, and then do the thermocure flush.
