I've had a 3" zone lift for 10+ years and I want to replace the shocks (RS5000X) and springs (already have BDS 3" front and 2" rear springs) as well as properly setup my bumpstops (hockey pucks) seeing as I've highlined and gone to 35s. I've been referencing the great threads from Fuse but still have a couple questions.
I've only worked on the front so far but I think once I get it dialled in the rear should go smoothly. I did miss getting a measurement with the tires off, and shocks disconnected but I believe thats only important for shock length and I can do that after. I removed the shocks and springs and put tires on to get my shock and bump stop measurements and came up with these numbers:
Passenger Side: Bumpstop: 3"
Shocks compressed: 16"
Shocks extended: 22.5"
Driveres Side: Bumpstop: 3"
Shocks compressed: 17"
Shocks Extended: 23.25"
First off, does 3" bumpstop seem like a plausible number? Not necessarily a good number or a perfect size, but with how my Jeep is set up right now, thats what I have to work with.
Second, my numbers for the shocks are different from each other, I'm guessing the axle just wasn't hanging, lifted level? So if I went with shocks that could compress at least 16" and extend at least 23.25" will that work? These look like they would fit that description if thats the case https://www.gorancho.com/products/s...er/rancho-rs5000x-shock-absorber-rs55239.html
Thanks in advance for the help!
