Hello WranglerTJ members. I’m new to this forum but have been a Jeep tj owner since 2006. I’ve found the tj to be an easy vehicle to work on but lately I’ve been running into challenges as I put on more miles such as changing a timing belt, new fuel pump, a new radiator but now I’m dealing with a dark hole. The starter motor. I’ve been dealing with a crank, no start situation for several months but now it’s become a no crank no start. The no crank has me at wits end. I’m looking at the ignition, the pcm, ecu, the starter. When I turn the key there’s power but no click, nothing. So I’m contemplating the direction to go but the starter fills me with dread. The location is near inaccessible. Today I did a practice run, checking what fittings to use. There’s two bolts , one low the other high up almost covered by the firewall. Help, there’s no way to get any leverage on the bolts I can see. Any advice? Thanks.
