Replacement axles are much harder to come by in the UK. No obvious donor vehicle options and shipping cost for replacement axles are eye watering. I am therefore looking at doing the best I can with a Dana 30. It is worth noting that the conditions in the UK are similar to the US East coast (not any deserts around here), so it is simply impossible to avoid wet and muddy conditions much of the time.
One option that is a possible replacement axle is a HP Dana 30 from an early XJ. If I upgrade an HP Dana 30 with a truss, 4.88 gears, ARB locker and chromoly shafts and run 35s, what is the most likely weak point in the set up given the typical UK conditions. Would 30 spline Chromoly shafts or RCVs change the answer?
