Backstory first.
I know the cooling system in the Jeep is very dirty. I also replaced the water pump, the t-stat housing, the t-stat housing a 2nd time after the 1st one was warped, and the t-stat. Once I got everything back together, I decided that I needed to do a Thermocure flush. I drained the cooling system, filled it back up with Thermocure and distilled water, and took it for a test drive. The t-stat worked, but I had forgotten to clamp down the upper radiator hose, so Thermocure+distilled water sprayed all over the engine bay. It is brown, sticky, and smelly.
I let it dry out and I started up the Jeep a few days ago. I just had it in my garage with the hood open. As it got up to operating temp, I started to notice a burning smell and some smoke. It was coming from along the edges of the valve cover, mostly on the driver's side. I thought some of the Thermocure goop had gotten into that area and was burning off whenever the engine got hot.
I took the Jeep to a local car wash today. I covered the PCM and the air intake and sprayed out the entire engine bay. I used some engine cleaner at first, and then rinsed it out pretty thoroughly with some light pressure water. I drove it home and let it run for about another 10 minutes.
The engine in still smoking from the valve cover area. Here's a video of the engine hot, but turned off.
I'm thinking that the valve cover gaskets have been leaking pretty badly and this is just the old oil burning off. But I'm new to this so I wanted to see what more experience people think is the issue.
