That puts things in perspective, much appreciated.
That means I need to figure out my spare tire situation first. And figure out my trail carry situation second.
I seemingly recall you mentioning in another thread, that you dropped your tire carrier bumper after the outboard, which changed your travel bias. Did you end up restoring it back to 50/50?
And you mention the 50/50 configuration, is that based on build philosopy or the position of the flutter stacks?
Enough has changed between then and now that both ends are within a fraction of an inch from 50/50. That includes moving and raising my rear upper spring seats during the initial rear outboard as high as possible to allow the use of spacers to adjust the ride height after sizable weight changes. My guess/recollection is that I changed the rear to a thinner spacer after removing the huge weight of the old bumper and tire carrier.
50/50 is part of a build philosophy that values up travel for both rig stability and to give the shock valving time and distance to work properly.
Within reason, the flutter doesn't know or care where in the travel bias it is. It still does what it does wherever there is a change in piston direction. What does matter in the travel bias is the main valving. On a 12" shock, 6" of up travel can be valved lighter than 2" of up travel because the longer travel gives the valving more distance and time to slow the piston travel speed before full compression. Less travel distance would require additional damping to prevent the shock from crashing into full compression.
