Can someone please tell me which wires do which function on a 2004 Rubicon front turn signal’s and how to keep the LED turn signals from making the lights light up the turn signal indicators on the dash with the new LM 407 relay
I thought it was a LM 470 relay?
I've got the electronic chops to get all my exterior lights converted to LED but to me the effort is not warranted. I have LED tail lights and LED headlights but LED lights in the turn signals and running lights are a PITA to get running properly once converted to LED. It partially has to do with circuits like the side markers switching polarity when the headlights are turned on which isn't allowed by LED bulbs which conduct in just one direction. To me it's better just to convert the circuits you're having trouble with back to incandescent bulbs so the circuit can operate as it was designed to.
It may be- It was late and I was tired
Either way I’ve got the same problem
I will verify the relay is correct
Great job on the fenders. I've always loved the look of @Plumber1's Jeep. I was hoping he would install some for me for some Tito's and Tacos.![]()
Did you get the side markers on, Just making sure you are replecating it correctly.
Well yes and no- I’m out of thread on the hood catch bolt since it is going through two fenders and now I wish I’d lopped off that corner but the bracket below it gives it all a lot of strength. I zip tied these on because I was so anxious to join the club.
I may use a stubby self tapping screw sheet metal and screw it to the bracket. Whatever I do I want it sturdy and clean. The bracket has a roll for strength that might be good to tap into.
I really went all out to wire brush it, prep unpainted metal, used urethane sealant at the bolt up connections, and instead of the rivets up top I had some milk jug screws- so I got some flat washers and nylon nuts and used those - looks good and stout.
I followed the entire “How to make your TJ look like Plumber’s” free download on the help page. I like the note on page one -“Caution- just remember, you might be in a Trans Am but you still ain’t Burt Reynolds when this is done”
I want to do a thread on my assembly, as another excuse to keep posting the same pictures over and over.
Your TJR has always been an eye catcher on here, and the cool thing is the places it goes.
I know it’s not been an easy year for you, and wanted you to know there are people out there that admire your rig and look forward to seeing you post.
Andy
Even with all the wires disconnected up front my turn signal dash indicators are both on- Now I wonder if I have the wrong relay or a bad one
The fix is making up some small diode/resistor packs that you splice to the side markers, which makes them independent of the front turn signal. Currently the side markers depend on the fronts for ground which is what screws everything up. Whether it's worth it or not totally depends on the owner of the Jeep and their preferences and capabilities. It's not difficult, you just need to understand the problem and what you're doing to fix it and then it makes perfect sense.
https://wranglertjforum.com/threads...de-markers-on-a-jeep-wrangler-tj.32114/page-3
Why did you need to clamp the fender to the tub like that? I don't remember having to do anything like that. Once you bolt the fender to the firewall and the grille it is in place.
Could you provide a link with the diode/resistor packs you used?
I use 3A diodes from DelCity and resistors from Amazon that come in a kit. Pretty much anything 1/2W or 1W for resistors will be fine. I don’t remember what ohm rating I used, somewhere around 5-600ohm I believe, but I use really bright side marker bulbs from VLEDS so depending on what bulb you use your needs will vary.
I use non insulated butt splice terminals from delcity, crimp it all together and cover in heat shrink, then tape around it. It is sort of chunky but it works fine.
