I suspect the bushing would wear away far faster than the housing will.
I would suspect this as well. The joint would fail well before any damage was done to the inside wall of the barrel me thinks.
This is a DF joint with approximately 35K miles of wear.
You'll notice a bit of scuffing around the circumference of the bushing. The OD of the bushing is no less than a new joint. the little bit of scarring is most likely due to me neglecting the maintenance of the joint for 35K. It was dry. there was a small amount of rubber transfer along the inside wall of the barrel in which the joint is housed. Cleaned the surface with a little brake cleaner and there was no evidence of wear of said surface.
