2006 TJ X with 4.0 and automatic. Everything on the steering column and steering wheel works. The cruise control will not work when the engine is cold. It makes no difference if it is winter or summer. Once the engine is up to temp, the cruise will turn on and work.
I should add that the engine runs perfect, no surging or other issues. Also, no codes.
TIA...
TIA...
