Brake rubbing sound
Gotta be hoses... could be a bad caliper...but I'd have put new hoses on from the get go.
I remember the crown brake lines that you suggested but they’re just taking forever and I need them asap and I’ve already waited 3 weeks for them. Any other recommendations? Preferable for a 2”, later 3” lift?
Lots of folks recommended the YJ hoses... apparently they're a touch longer.
You should be able to get the oem replacement YJ lines at any parts place.
They'll be plenty long enough.
https://jeepspecs.com/tj-generation/extended-break-hoses/
And yes...frozen caliper...not enough grease on side bolts...d hoses...all causes.
Just an added note for others, the bolts don't need greased; the slides do.
Reactions: macleanflood
I wonder if anyone makes a slide/bolt combo with a grease fitting.
If I do a particular wet muddy nasty trail ride I usually regrease the slides.
Probably unnecessary...
There's no metal for a fitting.
The grease goes in the rubber boot.
Yeah but you could drill the center of the slide with a hole to let grease out in the center into the boot...just like tractor and heavy equipment pins.
