Clearly, not a JL forum but you guys know more about wiring than I do.
I'm midway through the installation of the hardtop wiring harness and got to the section where you connect the new wires to the PDC
As you can see in the install instructions the BU/WH wire goes into the J1 position in the connector. I already have a larger diameter blue wire in the position where the picture looks like the wire plugs in. The note on the bottom says if a wire is present remove the wire and tape it to the harness.
My issue is I don't understand how to verify that the picture on the install page is pointing to the correct placement. If anyone knows how I confirm it is J1 it would be greatly appreciated. The way I'm looking at it is the downward direction is 1-7 starting at the top and the A-J would be from right to left. What makes sense to me is using that method the wire marked in the photo would be I-1 and the blank next to it would be J-1. Does the tiny hole in the middle of the raised portion count as a Letter making the whole harness A-K?
