Hey y’all, I was working on my jeep and I placed down my tool on a air line and it snapped in half due to brittleness if someone could help me identify what it’s called or where to get a replacement that would be great. See attached photos
If this is what you are showing us, then the vacuum line for the cruise control needs to be reconnected. That big thing is the cruise control servo that controls the throttle through the thick cable running to the throttle.
You don't need to piece anything together. Get some 1/8" vacuum line, cut it 2" long, use that as splices over the two breaks you have in the vacuum hard plastic line and go have fun. If you want to repair it closer to new, get some 1/8" nylon air line and use that to replace the hard plastic part.
BUMP Took my fender off last week with the intent of putting on after work the next day but the weather didn't cooperate. I've looked at diagrams but a few pictures would help. Can anyone post a couple pictures of where these vacuum lines terminate. Specifically the route they run. I think I may have gotten one or more backwards. Thanks in advance.
