I was really disappointed that I didn't capture that last few seconds where you hit that dip
I was also disappointed
I was really disappointed that I didn't capture that last few seconds where you hit that dip, my camera skills are poor.
Would be worth torque to spec just to know it’s good. Found my aftermarket TB loose once but I had a clunk issue not a shake.
Tire balancing confirmed good? Maybe also grab the front tires at 12 & 6 o’clock to check the wheel bearings.
I tightened up the lower track bar bolt and adjusted the tire pressures since it has been a while and the temps have gotten cooler.
I would say it's better, overall less shaking, but the underlying harmonic vibration is still there.
Did the harmonic exist when the rear DS was removed? What about before when both shafts were installed?
I’d be tempted to drive with the front DS removed to see if it goes away.
The jeep was all sorts of vibrating and buzzing at speed so I'm not sure, but probably.
The vibration was so bad that one time around 75mph, I swear my brain and eye balls were bouncing into each other
I know that I have one lower control arm that's pretty beat up. I'll crawl around under it tomorrow and get my wife to move the steering wheel around for me. Did you get the video I sent you by your email? My tablet is not letting me post any videos right now.
I didn't get the video, did you use the gmail address?
Boy it was cold! I turned around at the Petro. Could only maintain 60mph. The motor is tired. I'll need to stay closer to home.
Yes, maybe I copied it wrong. I'll check.
You might have to upload it to the Google Cloud
@RINC so u got towed back but u are going to keep driving and off roading it? This is a bit confusing.
Much better now with the new rear DS and SSSYEOk i kinda understand better…are things mostly better now but u still have a harmonic?
Shows up around 65+Does it show up around 40 mph+ and get worse with more speed or only at a certain speed?
Yup, they were balanced 2000 miles ago, used a pile of weights, so I know that it's possibly suspect.I’m sure you know that tire imbalance can cause vibration issues.
Geared to 3.73, pinion angle in the front changed slightly for the worse when I put on the taller front springs. Can't do anything about it right now.Maybe it’s a joint issue in the front DS that could be fixed. Are you geared lower now? How’s the pinion angle look?
Something to try if I feel up to tearing it apart again. Maybe when I put on the new trans oil pan whenever it shows up.I’d probably pull the front DS and if the harmonic goes away I’d look at your front pinion angle and driveshaft components.
And if the DS removal doesn’t change things at least you can move on. Best of luck man let us know how it goes.
Seems fine, at least with the tire on the ground.Edit: wheel bearings are good?
I don't know anything about the cloud. I did finally figure out how to load it on YouTube. Look on YouTube for David B. Turknett
I limped home.
Did you guys get your radios squared away?
