R ravenwooddrb1 New Member Joined Jan 22, 2024 Messages 4 Location Northern Idaho Jan 22, 2024 #1 I’m pulling my 4.2 engine it has a ax15 transmission hooked to it, my question is should I pull the bell housing with the engine or leave it attached to the transmission? Hope that all makes sense.
TheBoogieman Disturbed Supporting Member Joined Jan 1, 2019 Messages 11,646 Location CharlottesHELL, VA Jan 22, 2024 #2 I'm guessing you have an older YJ.
P P man Guest Jan 22, 2024 #3 TheBoogieman said: I'm guessing you have an older YJ. Click to expand... Per his profile he has a cj7 so I moved this Reactions: TheBoogieman
OP R ravenwooddrb1 New Member Joined Jan 22, 2024 Messages 4 Location Northern Idaho Jan 22, 2024 #4 TheBoogieman said: I'm guessing you have an older YJ. Click to expand... No it’s a 1984 cj7 Reactions: TheBoogieman
TheBoogieman Disturbed Supporting Member Joined Jan 1, 2019 Messages 11,646 Location CharlottesHELL, VA Jan 22, 2024 #5 I was too lazy to look at the profile.
OP R ravenwooddrb1 New Member Joined Jan 22, 2024 Messages 4 Location Northern Idaho Jan 22, 2024 #6 ravenwooddrb1 said: No it’s a 1984 cj7 Click to expand...
P P man Guest Jan 22, 2024 #7 To answer your question..the bellhousing bolts from the inside to your transmission correct? Reactions: John Cooper
OP R ravenwooddrb1 New Member Joined Jan 22, 2024 Messages 4 Location Northern Idaho Jan 22, 2024 #8 It appears to have 4 bolts on the outside bolting the trans to the bell housing.
P P man Guest Jan 22, 2024 #9 ravenwooddrb1 said: It appears to have 4 bolts on the outside bolting the trans to the bell housing. Click to expand... Are you sure it's an ax15? Reactions: John Cooper
