It is.
This is probably where they’re all the one row come from… You can buy them for $40 each in quanity… it sucks, but that’s the way it is now!
https://www.alibaba.com/product-det...yofferlist.p_offer.d_title.e898793eRddPJ0&s=p
It is.
I really doubt there's just one Chinese manufacturer turning out 1 row radiators.This is probably where they’re all the one row come from… You can buy them for $40 each in quanity… it sucks, but that’s the way it is now!
I purchased the Denso from Rock Auto and will be here by EOD Thursday.
Just FYI, I followed the recommendation of parts from this forum for a cooling system upgrade. Backstory, I just purchased this TJ on 12/22/23. I am going through freshening up a few items. Here's where I messed up in my opinion, the thermostat I ordered did not arrive with the pump, housing, hoses, gaskets, etc. So what did I do, went to O'Reily's and purchased one over the counter. I drove the Jeep afterward on Saturday, with no issue, then drove to work (40 miles each way) on Monday, and then back to work on Tuesday no issues. I have been paying extra attention to the temperature gauge. Well on my way back from lunch yesterday the engine temp shot up! Pulled over and realized after having it towed to my office (we have a conditioned shop) that the radiator blew apart.
A few thoughts:
1. The Jeep is 18 years old and bound to happen, I believe so at some point! I knew better, I should have just ordered the radiator when replacing all other cooling items.
2. The Jeep is 18 years old and working on and around the radiator on Saturday may put stress on the OEM.
3. The O'Reilly's thermostat failed? Planning on testing it this evening. *Anyone have a tip on how to test it? Boil water and wait for it to open.
Anyway, nothing crazy that anyone else hasn't already dealt with. Just my story and appreciate learning what others have learned.
A few thoughts:
Link to the Robert Shaw FlowKooler Thermostat
https://flowkoolerwaterpumps.com/products/robertshaw-330-160-degree-thermostat?variant=9125073354804
Great, thanks for the link and input. I am finding it odd that none of the stat's I can find online have the vent hole and position marking like the OEM I removed on Saturday. I'll post a picture tonight, haven't thrown away my scrap pile of parts.
The hole vents trapped air out which passes into the top of the radiator. Make sure the hole is positioned at the top when you install it so it can do that.What is the purpose of the hole? Assuming some type of vent...
From the Robert Shaw website, both options are in my year range. However, I am not sure what the difference is between the two options below.Link to the Robert Shaw FlowKooler Thermostat
| Make | CID | Ltr | Year |
| JEEP | 242 | 4 | 1989-2006 |
| JEEP | 258 | 4.2 | 1972-2006 |
Make CID Ltr Year JEEP 242 41989-2006 JEEP 258 4.21972-2006
No difference thermostat-wise. You do have the 4.0 though.From the Robert Shaw website, both options are in my year range. However, I am not sure what the difference is between the two options below.
X2!Just make sure you select the 195 degree one
I have run Slant thermostats for years in multiple vehicles with zero issues.
Denso or CSF? I thought the consensus was CSF.
Last I heard was Denso, but that may have changed.
