I've read all the vibration posts I can find and I'm stumped.
Background: This is a 2003 TJR that ran fine, no vibrations, no problems at all. I'm the third owner and the TJ has 160K on the clock. This is preventative maintenance since I had no idea when or if the u-joints had ever been replaced. There were no indications that the driveshaft u-joints were bad. With the exception of the centering yoke, I replaced all u-joints with Spicer non-greaseable u-joints. I installed a new Spicer greaseable centering yoke. The old u-joints were greaseable.
The u-joints in the front driveshaft had been replaced somewhere along the line. The rear driveshaft had the original u-joints. I know this because they had the plastic injected retainer. Replacement went ok and afterwards all joints are properly seated. They were not as shown in this image from @Jerry Bransford (see this link (https://wranglertjforum.com/attachments/u-joint-jpg.275904/)
Problem: Very slight vibration in the 30-40 MPH range and quite noticeable vibration above 50 MPH. The vibration increase as speed increases. I've double checked that the u-joints are properly seated in the yokes.
What is the next step in troubleshooting the vibration?
