I bought an 04 TJ about a year ago. Shortly after, I got the death wobble issue. After researching here & other places I traced it to the track bar bushing. I replaced the bushing with a 2 piece bushing set. Problem solved & everything was great for about 6 months. Couple of weeks ago my death wobble came back. I pulled track bar & noticed bushing sleeve again had an oval spot. I purchased a new 2 piece bushing set from different manufacturer that looks more heavy duty. Installed new bushing kit & still had death wobble although at a slightly higher speed range. Trying to find a solution, I temporarily loosened bolt that goes thru track bar bushing about 1/2 turn. It improved the wobble probably about 75% but was still there just not as severe. I did some more research & others are saying that the bolt needs to be super tight so I tightened bolt to point I was afraid of breaking it. Now the wobble is much more severe! I wouldn't think leaving the bolt slightly loose, even with locknut or double nutting to be sure it wouldn't back off, would be a good solution & would cause premature wear. I've checked all other joints & front end components & lowered tire pressure. I also had new tires installed & alignment done before intial issue. Any thoughts on how to proceed? I still feel I have some type of track bar issue since whatever I do to it changes the degree of death wobble.
