2004 Cummins 4BT Swap - 5-Speed Tremec 4050 - NP 205
You asked what the purpose of this build was probably to roll it up in nutshell a bullet proof expedition vehicle and also a test bed for either a 4 or 6 bt going in an older Landcruiser Wagon one of the FJ 55 and up or maybe an older Land Rover series II 88 or defender or possibly an old mid 70's ford F250 high boy
Interesting. Thanks.
Ok here are some a couple of pics of the damaged shift forks both were damaged I caught the one that had the crack the second one with hole did not show up till after some cleaning
  • Wow
Found a bad Outer Shaft Retaining ring. Turns that the retaining ring grove on the input shaft was available in 4 different thicknesses
.088
.091
.094
and
.097
Someone had been into this T-case before and used the wrong thickness retaining ring, so I have ordered a 4 pack of one each to get the right one
The Devil is the details hopefully the last of the PHQ me's
  • Sad
Well I found and ordered a case off of EBAY. I will get started on ot when it gets here, I am getting very proficient at assembly and disassembly
If you all have any requests for how to's post em up and I will try to take some time and get detailed photos and answers for youall
Didn't want to spring for one of the fancy aluminum cases I'm guessing?
https://www.totalmetalinnovations.com/Magnitude-205-p/magnitude-205.htm
That sucks but you're getting good at the disassembly and assembly part.
No picked on up off EBay for 90.00 plus 150 for ship
I keep looking for a used one near me that I can have on hand in case my t-case takes a shit on me but most around here are going for $300+. But I do plan on grabbing one at some point. Then a doubler from NWF and I'll have it as a back up.
Literally had the case torn completely down in about 10 minutes
You really are getting good at it.
Reactions: Rickyd
What are you using for T-Case and Doubler
I've got the STaK's 3 speed transfer case right now but they had a problem with popping out of double low. Mine wasn't before it was parked but I'm just trying to plan a head now. So if I was to get a 205 and a crawler box from NWF to go in front of it I could have close to the same double low I have now.
I have 3.05 low & 5.44 double low.
https://northwestfab.com/products/blackbox-np205-titan?variant=43246839660707
2.72 crawler box that only adds 5.35" to your length.
Whats the 205/203 doubler add
